DIMTMOVE system variable
文字移动
Specifies how dimension text can move.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 2 |
Default value: | 0 |
Possible values: |
0: Move dimension line with dimension text 1: Add leader when dimension text is moved 2: Allow text to be moved freely without a leader |
