DIMTMOVE system variable
Text movement
Specifies how dimension text can move.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 2 |
| Default value: | 0 |
| Possible values: |
0: Move dimension line with dimension text 1: Add leader when dimension text is moved 2: Allow text to be moved freely without a leader |
