DIMTOFL system variable
Dim line forced
Specifies whether a dimension line is drawn between the extension lines even when the text is placed outside.
Tipo: | Booleana |
Salvato in: | Disegno |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Don’t force dimension lines even when text is outside On (1): Force dimension lines even when text is outside |
