DIMTOFL system variable
强制标注线
Specifies whether a dimension line is drawn between the extension lines even when the text is placed outside.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t force dimension lines even when text is outside On (1): Force dimension lines even when text is outside |
