DIMTOLJ system variable
Tolerance pos vert
Specifies the vertical position for tolerance values relative to the primary dimension text.
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: | 0 to 2 |
Valore predefinito: | 1 |
Valori possibili: |
0: Bottom 1: Middle 2: Top |
