DIMTOLJ system variable
Tolerance pos vert
Specifies the vertical position for tolerance values relative to the primary dimension text.
| Type: | Short |
| Saved in: | Drawing |
| Range: | 0 to 2 |
| Default value: | 1 |
| Possible values: |
0: Bottom 1: Middle 2: Top |
