DIMTVP system variable
Text offset vert
Specifies the vertical position of dimension text above or below the dimension line when DIMTAD=0. The offset equals the product of DIMTVP and the height of the dimension text (DIMTXT). Setting DIMTVP to 1.0 is equivalent to DIMTAD=1
Type:
Real
Saved in:
Drawing
Default value:
0.0
