DIMTZIN system variable
Tolerance suppress zeros
Specifies the suppression of zeros in tolerance values. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Drawing
Range:
0 to 15
Default value:
0
Possible options:
0: Suppress zero feet and precisely zero inches
1: Include zero feet and precisely zero inches
2: Include zero feet and suppress zero inches
3: Suppress zero feet and include zero inches
4: Suppress leading zeros in decimal dimensions
8: Suppress trailing zeros in decimal dimensions
