DISPLAYSIDESANDENDS system variable
Display sides and ends
When ON, the sides and ends of linear solids highlight on hovering if the Quad is ON or bitcode 1 of the SELECTIONPREVIEW system variable is selected. The variable is available in the BIM and Ultimate license level only.
Solo-BricsCAD
Tipo: |
Booleana |
Salvato in: |
Disegno |
Valore predefinito: |
OFF |
Valori possibili: |
Off (0): Don’t display sides and ends On (1): Display side and ends |
