DISPLAYSIDESANDENDS system variable
Display sides and ends
When ON, the sides and ends of linear solids highlight on hovering if the Quad is ON or bitcode 1 of the SELECTIONPREVIEW system variable is selected. The variable is available in the BIM and Ultimate license level only.
BricsCAD only
Type:
Boolean
Saved in:
Drawing
Default value:
Off
Possible values:
Off (0): Don’t display sides and ends
On (1): Display side and ends
