DISPSILH system variable
显示剪影曲线
Specifies the display of silhouette curves of solid entities in Wireframe modes (2D and 3D) and whether a mesh is drawn or not when a solid entity is hidden in 2D Wireframe mode. To view changes on existing entities, perform a REGEN.
Type: | Boolean |
Saved in: | Drawing |
Default value: | Off |
Possible values: |
Off (0): Don’t display silhouette curves On (1): Display silhouette curves |
