DMAUDITLEVEL system variable
DMAUDIT command, level of details
Specifies whether certain types of errors are reported by the DMAUDIT command. The value is stored as a bitcode using the sum of the values of all selected options.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Area di Lavoro |
Gamma: | 0 to 3 |
Valore predefinito: | 1 |
Possibili opzioni: |
1: Ignore dynamic range errors 2: Ignore sliver faces |
