DMAUDITLEVEL system variable
DMAUDIT命令,详细级别
Specifies whether certain types of errors are reported by the DMAUDIT command. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: | Short |
Saved in: | Workspace |
Range: | 0 to 3 |
Default value: | 1 |
Possible options: |
1: Ignore dynamic range errors 2: Ignore sliver faces |
