DMAUDITLEVEL system variable
DMAUDIT command, level of details
Specifies whether certain types of errors are reported by the DMAUDIT command. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type:
Short
Saved in:
Workspace
Range:
0 to 3
Default value:
1
Possible options:
1: Ignore dynamic range errors
2: Ignore sliver faces
