DMAUTOUPDATE system variable
3D constraints recalculation mode
Specifies if a model automatically updates when 3D constraints are added or edited. If this setting is switched off, command DMUPDATE must be used to update the model.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t update 3D constraints automatically On (1): Update 3D constraints automatically |
