DMAUTOUPDATE system variable
3D 约束的重新计算模式
Specifies if a model automatically updates when 3D constraints are added or edited. If this setting is switched off, command DMUPDATE must be used to update the model.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value:
On
Possible values:
Off (0): Don’t update 3D constraints automatically
On (1): Update 3D constraints automatically
