DMPUSHPULLSUBTRACT system variable
DMPUSHPULL subtract
Specifies if a solid that intersects with other solids during a PUSHPULL operation subtracts from the existing solid.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Area di Lavoro |
Gamma: | 0 to 1 |
Valore predefinito: | OFF |
Valori possibili: |
Off (0): Disable DMPUSHPULL subtract On (1): Enable DMPUSHPULL subtract |
