DMPUSHPULLSUBTRACT system variable
DMPUSHPULL 减去
Specifies if a solid that intersects with other solids during a PUSHPULL operation subtracts from the existing solid.
BricsCAD only
Type: | Boolean |
Saved in: | Workspace |
Range: | 0 to 1 |
Default value: | Off |
Possible values: |
Off (0): Disable DMPUSHPULL subtract On (1): Enable DMPUSHPULL subtract |
