DMPUSHPULLSUBTRACT system variable
DMPUSHPULL subtract
Specifies if a solid that intersects with other solids during a PUSHPULL operation subtracts from the existing solid.
BricsCAD only
Type:
Boolean
Saved in:
Workspace
Range:
0 to 1
Default value:
Off
Possible values:
Off (0): Disable DMPUSHPULL subtract
On (1): Enable DMPUSHPULL subtract
