DMRECOGNIZE system variable
Automatic 3D geometry constraints recognition
Specifies which geometrical relations between the surfaces are maintained direct modeling operations. The value is stored as a bitcode using the sum of the values of all selected options.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Disegno |
Gamma: |
-1 to 508 |
Valore predefinito: | 0 |
Possibili opzioni: |
Negative: Switch off automatic 3D geometry constraints recognition 1: Tangent surfaces 2: Coincident planes 4: Parallel planes 8: Perpendicular planes 16: Cylinders perpendicular to planes 32: Coaxial surfaces 64: Cylinders and spheres of equal radius 128: Vertices between 4 or more faces 256: Edges between coincident faces |
