DMRECOGNIZE system variable
自动 3D 几何约束识别
Specifies which geometrical relations between the surfaces are maintained direct modeling operations. The value is stored as a bitcode using the sum of the values of all selected options.
BricsCAD only
Type: | Short |
Saved in: | Drawing |
Range: |
-1 to 508 |
Default value: | 0 |
Possible options: |
Negative: Switch off automatic 3D geometry constraints recognition 1: Tangent surfaces 2: Coincident planes 4: Parallel planes 8: Perpendicular planes 16: Cylinders perpendicular to planes 32: Coaxial surfaces 64: 相同半径圆柱体和圆球体 128: Vertices between 4 or more faces 256: Edges between coincident faces |
