DRAGMODEHIDE system variable
Hide original entity when dragging
Specifies whether the original entity should be visible or not when a drag operation is performed.
Nur-BricsCAD
| Typ: | Kurz |
| Gespeichert in: | Registrierung |
| Bereich: | 0 bis 3 |
| Standardwert: | 0 |
| Mögliche Werte: |
1: Hide original entity in 3D Modeling commands. 2: Hide original entity in 2D Drafting commands. |
