DRAGMODEHIDE system variable
Hide original entity when dragging
Specifies whether the original entity should be visible or not when a drag operation is performed.
BricsCAD only
| Type: | Short |
| Saved in: | Registry |
| Range: | 0 to 3 |
| Default value: | 0 |
| Possible values: |
1: Hide original entity in 3D Modeling commands. 2: Hide original entity in 2D Drafting commands. |
