DRAGMODEINTERRUPT system variable
Dragging interruption mode
Specifies whether the recalculation/redrawing of the model can be interrupted when mouse cursor is being moved (responsive, but may cause blinking, incomplete or disappearing graphics) or every drag iteration must be completed (slow, but graphics is always valid).
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: | 0 to 3 |
Valore predefinito: | 1 |
Valori possibili: |
0: Disabled 1: Enabled |
