DRAGOPEN system variable
Drag open
Specifies if a drawing file that is dragged onto the application inserts into the current drawing or opens as a separate drawing.
Solo-BricsCAD
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: | 0 to 1 |
Valore predefinito: | 1 |
Valori possibili: |
0: Insert file 1: Open file |
