DRAGOPEN system variable
拖曳图形文件
Specifies if a drawing file that is dragged onto the application inserts into the current drawing or opens as a separate drawing.
BricsCAD only
Type: | Short |
Saved in: | Registry |
Range: | 0 to 1 |
Default value: | 1 |
Possible values: |
0: 插入图形 1: 打开文件 |
