DRAGOPEN system variable
Drag open
Specifies if a drawing file that is dragged onto the application inserts into the current drawing or opens as a separate drawing.
BricsCAD only
Type:
Short
Saved in:
Registry
Range:
0 to 1
Default value:
1
Possible values:
0: Insert file
1: Open file
