DRAGSNAP system variable
拖曳对象捕捉
切换拖曳对象捕捉开关。
The DRAGSNAP system variable controls the snap behavior while 'dragging', providing an increased WYSIWIG experience. DRAGSNAP controls whether rubberband dynamics are displayed at the current cursor location or at the current entity snap location. DRAGSNAP applies to all modify commands that display dynamics, such as COPY, PASTECLIP, PASTEBLOCK, MOVE, ROTATE, MIRROR, SCALE and STRETCH.
When DRAGSNAP is off, snap is only in effect during drawing and editing commands; when DRAGSNAP is on, the cursor also snaps when no command is active.
Type: | Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Don’t snap dragged entities On (1): Snap dragged entities |
