DRAWINGVIEWASM system variable
Assemblies optimization
Enables the use of assembly data structures to optimize generation of drawing views. Toggles between normal analytical hidden line removal (HLR) and ASM_HLR procedure.
BricsCAD only
Type: |
Boolean |
Saved in: |
Registry |
Default value: | 0 |
