DRAWINGVIEWASM system variable
Assemblies optimization
Enables the use of assembly data structures to optimize generation of drawing views. Toggles between normal analytical hidden line removal (HLR) and ASM_HLR procedure.
BricsCAD only
Type:
Boolean
Saved in:
Registry
Default value: 0
