DRAWINGVIEWPRESETHIDDEN system variable
图形视图隐藏线预设
Stores the current hidden lines preset for the VIEWBASE command.
BricsCAD only
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | Off |
Possible values: |
Off (0): Don’t store the current hidden line preset On (1): Store the current hidden line preset |
