DRAWINGVIEWPRESETTRAILING system variable
Drawing view trailing lines preset
Stores the current trailing lines preset for VIEWBASE command.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t store the current trailing lines preset On (1): Store the current trailing lines preset |
