DRAWORDERCTL system variable
Draworder control
Specifies the default behavior for the display of overlapping entities. Use this setting to limit draw order if some editing operations take slightly longer. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 3 |
Default value: | 3 |
Possible options: |
1: Default display of entities with draw order 2: Draw order inheritance |
