DRAWORDERCTL system variable
显示顺序控制
Specifies the default behavior for the display of overlapping entities. Use this setting to limit draw order if some editing operations take slightly longer. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Drawing |
Range: | 0 to 3 |
Default value: | 3 |
Possible options: |
1: 打开对象的默认绘图顺序 2: 打开绘图顺序继承 |
