DWGCHECK system variable
Drawing check
Executes an automatic data integrity check when opening a drawing.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 3 |
Default value: | 0 |
Possible values: |
0: Warn on potential problem 1: Warn on potential problem and on other application 2: Notify on potential problem 3: Notify on potential problem, warn on other application |
