DXEVAL system variable
Data extraction update mode
Specifies the notification for data extraction tables. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Drawing
Range:
0 to 511
Default value:
12
Possible options:
0: No notification
1: Notification on open
2: Notification on save
4: Notification on plot
8: Notification on publish
16: Notification on ETRANSMIT or ARCHIVE
32: Notification on save + automatic update
64: Notification on plot + automatic update
128: Notification on publish + automatic update
256: Notification on ETRANSMIT or ARCHIVE + automatic update
