DXFTEXTADJUSTALIGNMENT system variable
Dxf text adjust alignment
Specifies whether alignment is adjusted when text is loaded from DXF file.
BricsCAD only
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t adjust alignment On (1): Adjust alignment |
