DXFTEXTADJUSTALIGNMENT system variable
Dxf text adjust alignment
Specifies whether alignment is adjusted when text is loaded from DXF file.
Solo-BricsCAD
Tipo: | Booleana |
Salvato in: | Registro di sistema |
Valore predefinito: | On |
Valori possibili: |
Off (0): Don’t adjust alignment On (1): Adjust alignment |
