DXFTEXTADJUSTALIGNMENT system variable
Dxf text adjust alignment
Specifies whether alignment is adjusted when text is loaded from DXF file.
BricsCAD only
| Type: | Boolean |
| Saved in: | Registry |
| Default value: | On |
| Possible values: |
Off (0): Don’t adjust alignment On (1): Adjust alignment |
