DYNCONSTRAINTMODE system variable
动态约束模式
Specifies the visibility of hidden dimensional constraints when the constrained entity is selected.
Type: | Boolean |
Saved in: | Registry |
Default value: | On |
Possible values: |
Off (0): Don’t display hidden dimensional constraints when the constrained entities are selected. On (1): Display hidden dimensional constraints when the constrained entities are selected. |
