DYNDIGRIP system variable
Show dynamic dimensions
Specifies which dynamic dimensions are shown. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
0 to 31
Default value:
31
Possible options:
0: None
1: Resulting length
2: Extended length
4: Absolute angle
8: Relative angle
16: Arc radius
