DYNDIGRIP system variable
Show dynamic dimensions
Specifies which dynamic dimensions are shown. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: | 0 to 31 |
Valore predefinito: | 31 |
Possibili opzioni: |
0: None 1: Resulting length 2: Extended length 4: Absolute angle 8: Relative angle 16: Arc radius |
