DYNDIGRIP system variable
Show dynamic dimensions
Specifies which dynamic dimensions are shown. The value is stored as a bitcode using the sum of the values of all selected options.
Type: | Short |
Saved in: | Registry |
Range: | 0 to 31 |
Default value: | 31 |
Possible options: |
0: None 1: Resulting length 2: Extended length 4: Absolute angle 8: Relative angle 16: Arc radius |
