DYNDIMAPERTURE system variable
Dynamic dimension aperture
Specifies the radius (in pixels) around cursor. This parameter is used only when DYNMODE flag is 16 'Nearest entity dynamic dimensions'. The nearest entity is looked for between entities which intersect or are inside this radius.
Solo-BricsCAD
Tipo: |
Breve |
Salvato in: |
Preferenza |
Gamma: |
0 to 500 |
Valore predefinito: |
20 |
Unità |
pixel |
