DYNDIMAPERTURE system variable
动态尺寸孔径
Specifies the radius (in pixels) around cursor. This parameter is used only when DYNMODE flag is 16 'Nearest entity dynamic dimensions'. The nearest entity is looked for between entities which intersect or are inside this radius.
BricsCAD only
Type: |
Short |
Saved in: |
Preference |
Range: |
0 to 500 |
Default value: |
20 |
Unit |
pixels |
