DYNMODE system variable
Dynamic input mode
Turns dynamic input features on and off. The value is stored as a bitcode using the sum of the values of all selected options.
Tipo: | Breve |
Salvato in: | Registro di sistema |
Gamma: |
-31 to 31 |
Valore predefinito: | 3 |
Possibili opzioni: |
Negative: Switch all off temporarily 0: No dynamic input 1: Dynamic input at pointer (not supported) 2: Editable dynamic dimensions 4: Tracking dynamic dimensions 8: Nearest entity by UCS X/Y axes dynamic dimensions 16: Nearest entity dynamic dimensions |
