DYNMODE system variable
动态输入模式
Turns dynamic input features on and off. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
-31 to 31
Default value:
3
Possible options:
Negative: Switch all off temporarily
0: No dynamic input
1: 指针输入打开(尚未支持)
2: 可编辑的动态标注
4: 跟踪动态标注
8: 通过 ucs x/y 轴动态标注最近的实体
16: 最近实体动态尺寸
