DYNMODE system variable
Dynamic input mode
Turns dynamic input features on and off. The value is stored as a bitcode using the sum of the values of all selected options.
Type:
Short
Saved in:
Registry
Range:
-31 to 31
Default value:
3
Possible options:
Negative: Switch all off temporarily
0: No dynamic input
1: Dynamic input at pointer (not supported)
2: Editable dynamic dimensions
4: Tracking dynamic dimensions
8: Nearest entity by UCS X/Y axes dynamic dimensions
16: Nearest entity dynamic dimensions
