EDGEMODE system variable
边模式
Specifies how cutting and boundary edges are checked with the TRIM and EXTEND commands, with or without extension.
Type:
Boolean
Saved in:
Registry
Default value:
0
Possible values:
Off (0): Use the selected edge without an extension
On (1): Extend or trim the selected entity to an imaginary extension of the cutting or boundary edge
