EXPERT system variable
专家
Specifies the display of certain prompts. If prompts are suppressed by EXPERT, the operation proceeds as though you entered y(es) at the suppressed prompt. EXPERT can affect scripts, menu macros, LISP and command functions.
Type: | Short |
Saved in: | Not saved |
Range: | 0 to 5 |
Default value: | 0 |
Possible values: |
0: Issue all prompts normally 1: Suppress 'regen' and 'layer off' prompts 2: Also suppress 'block already defined' (BLOCK) and 'file already exists' (SAVE and WBLOCK) prompts 3: Also suppress 'linetype already loaded' prompt 4: Also suppress 'file already exists' (UCS and VPORTS Save) prompts 5: Also suppress 'dimstyle already exists' prompt |
